My 2002 has new batteries and it runs great....sometimes. then it will shut down to a crawl, steady but crawling. going to try the diagnostics ....any other suggestions?
ok, tried diagnostic test ( turn key off, switch to run, switch from nuetral to rev. 5X, ) and only 1 single beep. It says i will herre a beep or beeps confirming it is in diagnostic mode then give codes....no codes folloewed. Anybody????????
Ok, I do see it (round magnet according to EZGO website like $40 bucks). I hate to seem ignorant, but does it just pull out, or do i pull the end cap of the motor off? does the wiring go to the controller area? I've been a fireman for 20 years and thats about all i do know about...sorry! william
There's 2 snap rings and a screw. Remove the first snap ring and the sensor will pull out. Then remove the second snap ring and screw and you can remove the magnet. There should be a wire connector under the cart for the wires coming out of the sensor. Check that connector first and make sure you have good connections there. If the connections are good replace the speed sensor.
Got the new speed sensor in....works great. Thanks to all that replied. I tried asking on another site called Buggies Unlimited, and never did get any help. I really appreciate it.
