Pimp Daddy
Thought I'd start this thread so everyone could post their suggestions to the NGKRA.Please NO BASHING here.
My first suggestion pertains to the rules that are posted on NGKRA. Some of the rules are kinda' vague.There needs to be more specifics on the construction of roll bars, cages etc. If doesn't have to be pinpoint, but a range of the sizes of tubing and thickness.I think rule number 4 needs to be restated so that it does not contradict. First it states that a golf cart chassis MUST be used.In the same rule it also states that approved aftermarket chassis may be used.
Like I've said, these are only suggestions, not criticism. Let's strive to keep it positive.
Here are the rules from the website:
The NGKRA 2010 rules
1. All participants must wear a helmet
2. All karts running faster than 9.99 1/8 mile must have roll bar and seat belt. Drivers head must be contained under roll bar
3. All karts running 9.49 or faster must have a cage that contains the driver in the event of a rollover and must have a 5-point sfi certified harness
4. All karts must run a stock style golf cart chassis, modifications allowed for roll cage, maximum wheelbase of 90”. Chassis width cannot be altered. Aftermarket components such as steering, suspension, brakes can be modified and used on such chassis. Approved aftermarket golf cart chassis allowed. See ngkra.com for approved manufacturers.
5. All participants in any NGKRA events must have competition number which is their kart number.
NGKRA Competition number must be visible on karts from the tower.
Each kart must have a spot to put their dial in on the kart
6. The NGKRA will not allow golf karts to race cars/trucks or motorcycles.
7. * New Rules and Rule Changes: NGKRA rules may be added, deleted and/or amended at any time by NGKRA. It is the participant's responsibility to stay abreast of all NGKRA rule changes that may affect the participant. All and any changes will be posted at www.ngkra.com under rules and on the NGKRA Golf Kart Forum under NGKRA rules. Any changes will be effective immediately upon publication.
* Only 4 wheeled carts will be allowed to compete in Super pro and Pro.
THE EXHIBITION CLASS
1. THE EXHIBITION CLASS WILL NOT RUN FOR POINTS WITH THE NGKRA.
2. VEHICLES MUST RESEMBLE A GOLF KART.
3. IT IS THE TRACKS DISCRETION WHETHER OR NOT YOU CAN PARTICIPATE.
4. ALL VENUES WILL NOT ALLOW PARTICIPATION.
5. IT IS THE RESPONSIBILITY OF THE PARTICIPANT TO HAVE THE PROPER SAFETY EQUIPMENT FOR THEIR VEHICLE.
6. IT IS THE PARTICIPANTS RESPONSIBILITY TO KEEP INFORMED OF SCHEDULE CHANGES
THERE HAS BEEN SOME CONFUSION WITH THE NEW NGKRA RULES....SEE BELOW
All karts must run a stock golf cart chassis, modifications allowed for roll cage, maximum wheelbase of 90”. Chassis width cannot be altered. Aftermarket components such as steering, suspension, brakes can be modified and used on such chassis. Approved aftermarket golf cart chassis allowed.
THE MAIN FRAME RAIL WIDTH CANNOT BE ALTERED, YOU CAN MODIFY A STOCK CHASSIS AS LONG AS YOU KEEP THE SAME STOCK WIDTH.
__________________
KART CLASSES
* SUPER PRO KART 0-9.49
* PRO KART 9.50-11.50
* SPORTSMAN KART 11.51 AND UP
ALL NGKRA POINTS EVENTS WILL RUN THIS FORMAT.
SOME NGKRA EVENTS WILL INCLUDE THE FOLLOWING:
* HEADS UP
* QUICK 8
* FASTEST KART
* FASTEST V-TWIN
* FASTEST 48 VOLT
* FASTEST 72 VOLT
__________________
KART CLASSES
* HEADS UP
* QUICK 8
* FASTEST KART
* FASTEST V-TWIN
* FASTEST 48 VOLT
* FASTEST 72 VOLT
