Still Having Problems With No Spark At Spark Plug Or Coil
LUGNUT43
read my post ..where i am still having problems.BUT I TRIED THE THREE WAY SWITCH BUT NOTHING.......AND NOW I HAVE OTHER PROBLEMS....IT JUST QUIT RUNNING...I HAVE A NEW COIL POINTS CONDESER.PLUG.AND PLUD WIRE..BUT I CANT FIRE TO THE PLUG..OR COIL OR ANTHING..IT TURNS OVER JUST NO FIRE....NOW I WIRE IT BACK UP THE OLD WAY WITH THE SWITCH STILL STUCK IN REVERSE..I CHANGED THE WIRE ON THE SWITCH TO RUN FORWARD AND IT RAN ALL NIGHT THEN JUST QUIT.....SO CAN YOU HELP
LUGNUT43
hello sorry i havent been on here much i am still having problems with my 1984 hd cart 4 wheel. type...the key is stuck in reverse,,,,and wont turn it was running ok..backwards so i swaped the wires around on the switch where it would go forward it ran like that for about 2 days...now it will turn over put wont start..i am not for sure how a 2 cycle works,,,,but i know with a volt meter when its turning over there is power to the coil....but there is no power to the points that i can see or tell....i ahve change the points and condenser again...and coil..but still wont run...how does this thing wire..and all so how can i do away with the bad switch and just use a toggle switch i havent tried it ever which way...but i can even get it to turn over..unless i put back the ole bad switch.........im about to take a gun and put the cart out of its misery lol....i have tried ever thing i can think off can any one on here help me please all...suggestions are helpful///
