Still Having Problems With My EZGO That Stops Running
skindaddy
i assure you as we were doing circles as we go there is no voltage across the lrg. that is why i thought hey why not test the small to see if any reading, then back to large nothing. i really am not good at tracing electrical , but i can read an electric tester ;) . by the cables you mean cause there not crimped? if thats the case i have a large crimper at work. and they are #4 welding cable now just not out of a package/factory
The lugs on the cables don't look like they're put on the cables very good and can cause problems if their not.
I really don't know what to tell you about the large posts on the solenoid not having power and the golf cart actually runs like that. The only way I know of that the cart could possibly run with no power to the large solenoid posts would be if someone somehow bypassed the solenoid.
skindaddy
they are soldered on, thought it was a good idea at time,
was wondering if i had sometihng wired wrong and just got by all these yrs, i see if i can come up with something tonight.
i think i still have a diargram i printed from this site i think, i'll check my folder.
Soldering the ends on is fine as long as it's done right. Maybe it's just the pictures but they don't look to good.
Maybe someone else will chime in with some ideas and if you find anything after going over the wiring diagram let us know.
Good luck :)
skindaddy
i checked some more with tester, but need to clarify when you say voltage across large post on solenoid, are you saying touch one lead to each of the lg post correct? as in across the 2
The best way to check is one post at a time positive lead to the solenoid post and negative lead to battery pack negative.
skindaddy
ok good i finally got that(i am a moron) , i misunderstood you said across post. battery neg to each post i have 38-39 volts.
i really dont know what to do now went through all the wiring everything seems to be in right place, nothing loose.
Have you checked for power on both large solenoid posts when the car won't run? My guess is either the solenoid stops working when you drive a while or the controller is going in to thermal shutdown.
skindaddy
quit many times this weekend one time was different, i was driving and it was cutting in and out every few seconds then died at about 80yds, tow it half way back and it fired up drove rest of way.
so yesterday i took apart bunch of cables also at f/r switch crimped all large 4ga cables to rule that out, replaced the couple small ones that got hot on solenoid with little bigger wire too, cut off a couple more ends and replaced to rule out those.
tighten every connections with bolt/nuts put back together and NOTHING. so i know it wasnt from heat also i;ve never felt any heat on anything ever after quitting.- so after pushing go pedal 40times and wiggling wires and still nothing , i walked away for a few minutes to cool me down and walked up and pushed pedal and stupid thing took off!!
notes
had voltage across post after quit at least first time
can hold pedal down and wiggle/jerk every wire and never get it to jump or work ever.
axe controller led reads normal operation flashes green then goes solid green even under not running situtation
also took prob over an hour messing with wires so it was not hot and didnt work.
can anyone tell me how to remove motor? do i just unbolt and pull out of gear housing? nothing will fall apart at housing or come undone that i wont be able to slide motor back in?
has new solenoid(same results as old solenoid), f/r switches , micro switch in foot pedal, yr old batteries (38-39volts),and now a couple new wires.
skindaddy
thanks i got nothing to loose, gonna just give it a peak and see, i figure its either this or the controller - even though led lights read correct.
skindaddy
took motor out brushes look good a few marks on armature but nothing bad, blew out put back together, tore f/r switch apart, fixed one more wire, took controller apart but that thing is sealed like a drum.
runs but sometimes still has issues , only thing i can think of is controller, i cant see spending that much cash on it at this point, just keep going as it is.
skindaddy
Well it's me again/still, been having same problems since and still last post. Will work awhile then all sudden stop again. Controller always reads green LEDs that all is well even when won't move. The way I got it to work all summer if failed was to tap one of the post on controller with hammer always same one and would always work.
Question can the controller still be bad if the LEDs say ok??
It's only thing I can think to replace, been out of this cart thing awhile anyone know what the cheapest aftermarket controller there is I believe I have an axe controller now.
Idk what else foot pedal controller? But has to go through that first before controller and LEDs read good.
Sucks this thing isn't worth a whole lot, and can't figure out the bad part.
What make and model is the controller? When the golf cart stops moving does the solenoid still click when you press the throttle pedal with the key on? Is the controller or any cables getting hot while your driving the golf cart? Did you ever redo the ends on your cables? What you're describing is usually a sign of the controller going in to thermal shutdown, bad connection at one on the cables or the solenoid is dropping out.
skindaddy
Alltrax AXE controller, replaced solenoid, yes still clicks sounds normal but no go. After click hold down pedal like driving LEDs on controller go through sequence show all is well.
Yes crimped end better or replaced.
One wire was warm on solenoid, but replaced with bigger almost year ago plus didn't look good anyway so replaced.
I read through the entire thread again and the only thing I can think of is if tapping on a terminal on the controller makes the golf cart run I'd say either the cable on that terminal isn't making a good connection, there's a bad connection inside the controller or the solenoid has a bad connection or is bad. Seeing how the solenoid is mounted to the controller when you tap on the controller terminal you would also be shocking the solenoid.
skindaddy
Ok thanks for the help again. It's so frustrating, double checked connections all tight. Idk have to figure out the cheapest controller I can get and maybe try that. Just stinks LEDs all read good unless it's on the output side after the led Indicator, whichever that is.
