stereo
mountaindew
I have a 2005 club car lifted.It has 4 12v batteries which is 48v.My question is I bought a radio for it and it seems to be running one of the batteries down.Does this make any sense.It doesnt seem to me that a radio would run one the battery down as quick as it does.One person told me to hook up a rocker switch so I could shut it off when I am finished listening to it but then I lose all the memory.Has anyone had the same problwm
dougmcp
How long is the radio on for?
Do you also have an amp?
How do you know it is running one battery down?
You don't need a rocker switch, just turn the radio off.
There should be a yellow (?) wire to connect to the battery that will save your settings in memory.
mountaindew
Thank you for your response.I found out there was a short in the CD player that was causing the battery to run down.Replaced the radio
