steering problems
phillg07
i have a 2004 txt gasser my front end wanders all over the place when i hit a bump and when i make a sharp turn i have to turn the steering wheel alot to straighten the cart out any ideas is something get worn steering wheel feels like it is not loose
Is the cart lifted? How much play is in the steering wheel?
Have someone rock the steering wheel back and forth while you look under the front of the cart to see where the play is. If you don't see anything obvious jack the front up and grab the front tires and rock them back and forth. You should be able to see where the plkay is with no problem...
If everything looks good check your toe in...
phillg07
thanks for the info if it ever stops raining at the campgrounds i will check it out :tip:it has a 4 inch lift
JRay
If yout toe in isn't set right you will get bump steer with a lifted cart. Do as HRC suggested first, if all that is good toe it in some more.
