Starting problem
Jimyoung
I have a problem starting my Hyundai gas golf car. It will not crank over unless it is connected to a charger. I replaced the battery so it is new. it will run after it is started but when I stop, it will not start again until I put the charger on it. Could the starter-generator be bad?
I agree with riverrat006, it's probably the brushes in the starter generator. Make sure you have good connections everywhere also.
shadowman
if the solenoid is bad it still shouldn,t start by putting a charger on it? i would test the voltage regulator and if its good than look at starter brushes..........even though you say its a good battery i would still test and load test it............it may take a charge but be bad under load..............................................
Jimyoung
Its a brand new battery. Also tried two other batteries that I know are good. One problem I have is I live 90 miles to the nearest place that works on golf cars. Living in the hills has a few inconveniences.
Jimyoung
Well, after all the head scratching, and phone calls,
I took the starter relay off and put it back on and......
..........................................................wala........it works. Guess a little corroded terminals.
Thanks to all that tried to help....
