speedway1839
Having trouble with my '93 cart. The electric starter/generator will work for a while then quit. Checked voltage on starter side of solenoid and had 11 plus volts. Also have 11 plus volts at starter connection. Pulled starter out and checked brushes, they are fine. Hooked unit up to my heavy duty battery charger/engine starter and the unit ran flawlessly. Cycled several times to see if there was a bad spot on armeture no problems whatsoever. Looking for any ideas anyone might have.
Thanks,
Mike
Thanks,
Mike
