ST Sport 2+2 Solenoid Problem
EZWillie
I purchased a 2011 St Sport 2+2 recently and after driving about an hour stopped to open garage door to park cart. Cart wouldn't start just a couple of minutes after I had been driving it. Checked the solenoid and found no contact on top terminals when trying to start. Ordered another solenoid and after about 15 minutes of running I stopped the cart and once again couldn't get it to restart. Checked the solenoid and found same problem. Thought maybe the solenoid I bought was defective, so....
you guessed it-bought another one from different supplier and it also met the same fate. Ideas anyone? Could the voltage regulator be the problem?
Imported solenoids are 99% trouble, problem solved below:twocents:
WHITE RODGERS 12 VOLT 100 AMP 4 TERMINAL CONTINUOUS DUTY
EZWillie
I checked both volts and ohms. Volts while still hooked up in cart, and then bench checked w/12 volt jump battery and no continuity.
