Should I Replace the Solenoid?
41canine
I have a 2008 48V Precedent and replaced the controller with an Alltrax. Is it necessary to replace the solenoid too?
Also, I had the dicor switch replaced and now the Go pedal is very touchy. There is no easy taking off forward or in reverse. It takes a lot to smoothly take off. Is that to be expected?
Thanks for any help or advice.
Zman
What amp Alltrax controller did you buy? If you have a 400amp or bigger i would get a heavy duty solenoid rated for the amps. Also reprogram the throttle up setting for a smoother accel rate and/or the throttle down rate as well. a good balance between the 2 should cure your touchy pedal.
41canine
Thank you Zman.
I'm not sure on the amperage of the controller but will check it out. Regarding the adjustment of the throttle, I thought that was adjusted through the controller and that the. Alltrax wasn't adjustable. Is there another way to do the adjustment?
Thank you
shadowman
if your alltrax is an APX its adjustable if its a NPX its not.......you should put a HD 400 amp solenoid in to be safe...................................................
