Rusty Frame
The rust was all ready on the frame when I purchased the cart.
The rear of the frame seams solid but the front has a few areas of rust.
It's been holding up so far. Should I be concerned?
Rust is never good so yes you should be concerned. It will only get worse. As long as the main frame rails are solid it should hold up for a while.
rust is a hard thing to stop, been goin' through that here in wi forever. the land of rust
theres sprays out there that kinda work to slow it down, its the rust inside the frame rails that ya can't get at that will be its death.
i would spray something like this on the spots first and then top coat with your color
