Ruff & Tuff got wet - now goes slow
tillerwiller
I went through some puddles in my R&T with QuiQ charger (onboard). The cart ran fine for at least 10 minutes after the last puddle. I parked the cart for about 30 minutes and then it would not move again. I let it dry overnight and thought it would work in the morning. It did not. I later loaded it onto a trailer then noticed it worked again, but would only go very slow (less then 5mph). I let it dry a week now and still only 5mph (like is has very low charge). The guage shows 3/4 full and the QuiQ charger will not charge. It shows a double blinking red light fault. Can anyone give me any advice on this?? Cart is about a year old. Thanks.
I don't know what the codes are for the QiuQ Charger are so maybe someone else will chime in on that. I'd start with checking all your cable connection to make sure they're clean and tight.
Zman
6 blinks is a internal fault watch dog code. You need to send charger in for repair or replacement.
dirtysouth
