Rough Ride
G-Man
I have a new EZGO ST 2+2. THe thing rides like a tank. I have the 22" tires at 12#. Anyone have suggestions on how to soften it up?
Help my back is killing me
not so fast
Thank God I'm not the only one, 05 ST 350 2+2 with axle type lift 23" All Trails and rides like POOP. I'm tired of it, so tomorrow I'm looking at a long travel kit, probably like Jakes. I hope that solves the problem.
Airing down the tires works somewhat but it wears the tires out BADLY on the street!!!!! Wish me luck ;) NSF
COPB
If you have heavy duty springs, try taking out a leaf or 2. Those HD springs really stiffen up the ride.
not so fast
As far rear springs go, I am down to 2 leafs from 5 to try and soften the ride. It was so stiff that 2 grown men hardly made a dent. I tried running 5 lbs air and it was ruining my tires outside tread so watch that. I usually am by myself so it only made sense to make it softer. Buying the Jakes long travel (#6210) tomorrow and hopefully the stiff ride will be gone!! NSF
COPB
That may be one cure, but I must point out that there is probably a cheaper fix. Of course, you want a long travel suspension. :)
Ga_goat
Come try the one I just got , 14" lift 14" wheels and the rear shocks are square tubing , solid lock , I'm changing that when I get a chance to. :bump:
not so fast
Not really but I DO WANT A SOFTER RIDE!!!!! The Jake's long travel is what just about everybody has suggested hence that's what I'm getting but way too much $$$$$$$$ IMO but supposed to be good quality right?? Just so it works. NSF PS also found out my buggy is not a 350, just a ST 2+2
