robin 244 specs needed
equiprepairsv
Hello I have moved this discussion from the 4 stroke catagory for obvious reasons.
I need to know what the gap specs are for the points on a 244 and if they can be set with the flywheel still on (there is a removable cap). If the flywheel needs to be removed is this a standart thread or reverse threaded? My bolt seams not to want to move in either direction.
mb523
Sorry for the belated response.
The points can be adjusted with the flywheel on, you just need to remove the dust cover in the center to access them. I am unsure of the specs, I will try to find them for you.
