Resistor type Hyundai Electrical
thelt
In the drawing attached, look at the Main Switch. It shows a R and Br wire going to a plug. The plug is a four pronged plug. There are two other wires on here that go to the switch (B and B with R tracer). What are they for? They're not shown on the diagram or Hyundai used a different standard in their electrical drawings that I'm not used to seeing. There is also two other wires on the switch that go to a separate plug which is not plugged in to anything. What is it for?
Nate
I can't guess what those other wires would go to, all I can say is a GC shop in Arizona was having a real fit trying to figure out a Hyundai and they called me to come up and take a look. I stopped trying to figure out what Hyundai did and why and rewired the cart using their parts. All safeties were still in place but the wiring was much simpler after I was done.
thelt
Thanks for the reply Nate. I rewired mine with an EZ-GO switch and left the other wires disconnected. Only used two wires to turn it on and off. Seems to be working fine for the time being.
Nate
Thelt, the only thing I recommend for a custom wiring is to set your main contactor to disengage every time the accelerator returns to "Home". If something ever went wrong you would lift the accelerator even before you hit the brake pedal. Sounds like you did wiring similar to what I would do.
