Resetting Club Car OBC
Status
Not open for further replies.
Club Car Golf Cart On Board Computer Reset
To reset the Club Car OBC the following must be done in this order:
1 - Key Switch to Off
2 - Forward/Reverse to Neutral
3 - Tow/Run Switch to Tow
4 - Disconnect the Battery NEGATIVE (–) wire from the battery NEGATIVE (-) terminal on the battery pack.
5 - Put the Tow/Run to Run
6 - Forward/Reverse Switch to Reverse
7 - Key Switch to On
8 - Lock the throttle pedal down
The reverse buzzer will sound and go off in about 30 seconds. Leave the cart like that for 5 min to cause the OBC to reset.
To reconnect the OBC back into the system:
2 - Forward/Reverse Switch to Neutral
3 - Tow/Run switch to Tow
4 - Reconnect the Battery NEGATIVE (–) wire to the battery negative (-) terminal on the battery pack.
Status
