Replacing FNR switch with Solenoids
SPLMAN
I'm looking to replace the Manual F N R switch in our EZ GO TXT with high powered solenoid/relays.
It looks like I will need to use (4) 200A solenoids to accomplish this, and maybe a smaller relay or two.
How much amperage does a typical cart pull? I just want to make sure the solenoids will handle it.
We've gutted ours and will be doing quite a bit of custom fiberglass work as a demo, and would much rather have a switch control it.
Any input would be appreciated
dougmcp
That's an costly venture but since you asked, 200 amp continuous duty solenoids are fine for most uses.
shadowman
why are you using 4 solenoids? for like a power boost or something? if so be careful you can ruin the motor..............................i,m just curios........................................
dougmcp
If I understand correctly, to take the place of the big F-N-R switch on the seat panel.
He wants to use a low amperage switch to control F-N-R functions.
shadowman
i,m curios as to why 4 soleniods....have to say i have never seen anything like that for that application but than again there are a lot of things i havn,t seen.................................................
SPLMAN
Sorry, I never got the email notification of any responses.
The only reason I would be using 4 is because 2 post solenoids are readily available in my industry.
If you perhaps have a link to the 6 post ones you mentioned, it may be more cost effective or space effective for me?
SPLMAN
Yeah, but I don't have SPAM filters active.
Happens on one or two other forums, but works fine on most, not sure why
I know a lot of forums have problems sending mail to AOL and Earthlink accounts for some reason. If your email address is with either ones of those that may be why.
