I'm attempting to remove brake cable from the front bracket housing. The removal went fine with the tool supplied in the kit in the rear assembly ; however, when attempting to remove from the front brake pedal housing, the spring loaded cable stop would not depress enough even with the tool to pass back through the hole. 2 or 3 of the prongs are stuck and will not depress in order to be removed from the hole. Any suggestions??
