Removing Driven Clutch fron 02 EZGO
Rich K
Can someone tell me how to remove the driven clutch form a 02 EZGO? How do I tell what model cart I have? Thanks
the driven likes to freeze on sometimes, i jack up the left side of the cart and spray wd-40 etc in the bolt hole and let it sit for an hr or so and do it again. some guys use a large pickle fork for ball joints and tap it between the driven and the case, you may be able to just tap side to side on the clutch, all depends how tight its on there.
Rich K
Thanks guys, the clutch came right off, that usually isn't the case for me. I took it to the shop to get a heavy spring put in. It will be ready tomorrow.
post back how it worked for ya
