I welded [2] 1/2 inch bolts after barely threading them into the lug nuts so I could screw them on opposing lugs and used a bar puller to pull some difficult hubs off. Slide hammer works well to if you can connect it to the hub after of course making sure the nut is removed and brake pedal released. I usually make sure the hub rotates with the brake pedal released and if not back the adjustment back until it will rotate easily as sometimes the cable will stick and keep shoes engaged even with the brake pedal released.
