Reciever for front
rhgc
I have a 2003 EZ-GO and I am wanting to mount a reciever hitch on the front. Im wanting to use it for a winch, this way I can use the winch on the front and rear (already have a hitch on back) I cant figure out how to mount it. I have a spindle lift so the stock axle is my problem. there is nothing flat enough to bolt the hitch to. any ideas??
Batman
If you want it to be strong you need to make a bracket that mounts to the spring mounts on the frame and the shock tower. The only other place is the front axle itself and they're not to strong on the new style steering. If you do mount the winch to the axle you better box the axle in.
cartdr1971
EZ-GO has a front hitch available for the ST350/ST480 that has basically the same front axle, just different spring plates.
