rebuilding a g1 gas
hotrodharley
have a 84 gi gas cart..thinking it needs rebuilt..run when i went looked at it to buy[trade for] but had to have choke part way out..2 months later when i went back and got it wouldn't start at all[cranks but won't start]thinking since i already have cart apart to chop top/make some mods to body and paint then this would be good time to freshing up engine..new to carts.never even drove one till got this one and haven't drove it yet;;
to do a rebuild what should i do?like to get more performance from it since already rebuilding.don't want to go to changing engine..just get most out of what i have now but do have a budget to stick too.so what do i need and cost roughly to do a rebuild and hop-up at same time???
my thoughts are;;;bore cly to max with new piston and rings;;[what is save bore?]
do something to heads[shave and what ever else if anything[how much to shave off and over work]c
bigger carb[what can i use as a donor carb without major modifications]
exhaust;;maybe a hp muffle off some kind of 4 wheeler or motorcycle[stay under body if possible]
anything else maybe..
do i just need to do upper end and replace the 2 seals[behind clutch and fan]
what cost range would i be into it?whant to do ASAP
