So i got my first cart, witch will be used at the track just to get around. I bought the cart it had all brand new batterys not installed yet. so today i put them all in wired her up and it runs great. the only thing is it has moan coming from the motor/rearend. its only when it is under load if you let off the gas its smooth no noise. Just wondering if there are any common problems, or certain bearings to look for. i cant imagine the ring and pinion making that much noise. and i made sure it had gear lube thanks!
btw its an 83 ezgo
btw its an 83 ezgo
