Rear suspension
tamnoz
Everybody sells lift kits and double a-arm front suspensions but does anybody sell something to let the rear articulate. If the rear axle has to stay flat the front is useless. I was thinking if you took the swing frame and connected it in the front with one big hiem joint and then put a panhard bar in the back the rear suspension could work with the front to make a truly flexible golf cart. Any input would be truly appreciated, my other option is to buy a 4x4 IRS ATV and build a 4x4 golf cart.
JIm
dirtysouth
G14 and newer have a single pivot at the front with a trac bar at the rear. G1/ 2/9 are all two pivot at front/swing arm.
