Rear axle bearing replacement.
Southerncomfort
Ok from what I've learned remove the snap ring and the axle comes out.
Bearing and press collar is pressed on.
I've got a new set of bearings, but before I dive in is there any other parts I may need or things I need to know ?
That's pretty much it. Remove the snap ring, take the axle out, press old bearing off and new bearing on.
Southerncomfort
What I thought and seen it on here, just wasn't sure if there was an extra seal or something I wasn't seeing.
The old ones I bet are the original bearings, rather replace them now and not 5 miles back on a trail.
Fronts are the good ol tapered roller, and I bet they should be fine other than needing cleaned and repacked. But wondering if I had better order new seals in case I tear the old ones up getting them out.
