I assume you are asking about the factory steering wheel. It is easier if you have a helper to pull tention on one side and with a block of wood against the column and to the bottom of the wheel, hit it with a hammer opposite of the side with your helper pulling. Take the bolt out ahead of time and give it a spray of good penetrating oil and let it soak in, that helps.
