Problems with a 2005 EZGO. Can someone help???
jrob71184
I have a 2005 EZGO and when you first try to start up it takes it a while and it seems like it is flooding. But when you get it started up it will run fine then after riding for a while and stopping for a little while it doesn't want to go again just turns the motor over. I put new plugs in it a day or so ago and made sure the air filter was clean. What could be causing this? Could it be firing weak? Clogged carb? Fuel filter? If someone can give me some suggestions i would really appreciate it!!!!
Start with adjusting the valves. .006 with the engine cold. There's instructions on adjusting the valves in the EZGO resource forum..
ftfixer
manual choke ? if yes make sure it is set properly what about gas fumes? how did the plugs look when you changed them black,smutty,wet or clean ?
jrob71184
Will the vavles just get out of wack that quick? One plug was wet and black and the other looked to be burning fine. Would it still run fine when you got it going if one of the plugs isn't firing properly? it has a manual choke on it. How would i check to make sure its set properly? I have had the cart probably a month and the only thing i have done to it motor wise is change the plugs and clean the air filter. This is the first one i have had so you guys are helping me alot and i really appreciate it!!!!!!
ftfixer
the intake valves will tighten on these engines quite often you probably need to adjust the valves before trying anything else 1 plug being smutty and wet could definitly be valves need adjusting. how did the plugs look when you replaced them? also check the plug wire to make sure it is pushed down into the coil far enough and that it is connecting to the plug as it should. adjusting valves is simple if you have a printer you can print the procedure with pictures step by step thats what i did. i believe hrc posted where you could find the procedure complete these things and let us know how it goes then we can discuss the choke and carb.
jrob71184
Ok i will try these things yall are telling me. My dad appreciates yall's help as well cause he has been having about the same problem just not as bad as mine. As soon as i get it adjusted i will let yall know!!! Thanks in advance!!!!!!!!!!
jrob71184
Ok thanks! I'm gonna try and do it tomorrow if not then it will be before the weekend for sure and i will let yall know. THANKS!!!!!!
jrob71184
Well got them adjusted and it runs like a champ!!!! Thanks to all yall it was a easy fix. My dad says thanks to cause it straightned his out to.
jrob71184
Oh yeah thats what it was. When we got them adjusted it took off faster than the day i bought it so it may have been having a little problem since i got it. I have only had it maybe a month or so. Once again thanks for the help everyone!!!!!
