Hey folks. I have a 2016 Club Car Precedent (JE1611) 48 volt sepex motor that I just installed an Alltrax XCT 400 controller, 200 amp solenoid and 2 gauge cables and having problems. After install the cart does a pulsing type movement in both forwards and backwards. Like a slight bucking (go/stop/go) and only moving about 1mph in three processes. I didn't do it long because I figured the contactor was for some reason opening and closing fast and I didn't want to damage anything. I yanked everything apart and double checked all the connections according to the alltrax paperwork as well as the paperwork that came from the company I purchased from. I was told by the seller the controller would be set up with the proper field map and settings for my particular cart. I did a battery test prior to the install across the pack, each battery separately and under load across the pack using a volt meter. All checked good. Can anyone offer some suggestions? Does this sound like somthing anyone has ever ran across? I appreciate any input you can offer!
