precedent clutch removal
shadowman
front or rear? if its the rear just take the center bolt out if its the front you,ll need a C.C. clutch puller.............................................
mtj448
It's the drive clutch and I understand the need for a puller, but there doesn't appear to be room enough to get the bolt out and the puller in unless you drop the engine??????????
shadowman
no need to drop engine you can get the bolt out and you can get the puller bolt in..........you, need in most cases a 1/2 inch ratchett and wouldn,t hurt to have a extension........look in from the front of pass side wheel depending on tools if you have an air gun take the rear wheel off but i assure you no need to drop engine......................................................
