Powerwise QE and Delta Q Charger Fault Codes
Status
Not open for further replies.
LED OPERATION CODES:
SHORT GREEN FLASH = less than 80% charged
LONG GREEN FLASH = more than 80% charged
SOLID GREEN = 100% charged
RED FLASH = fault code
LED FAULT CODES:
RED FLASH: Light turns on briefly, but does not
flash after that - check for valid AC voltage.
ONE RED FLASH: One flash, a pause and then
again one flash and a pause - Charge Enable
Fault: poor contact in the DC connector or dirty
contacts or Battery Temperature Fault: battery
temperature is greater than 122° F (50° C) or less
than 14° F (-10° C).
TWO RED FLASHES: Two flashes, a pause and
then again two flashes and a pause - Battery Voltage
Fault: Battery pack is less than 36.0 Volts or
more than 67.2 Volts. Battery pack is too discharged
or over charged for the charger to work.
THREE RED FLASHES: Three flashes, a pause
and then again three flashes and a pause - Battery
Charge Time-out: Charge time exceeded 24
hours. This may indicate a problem with the battery
pack or that the charger output current was
severely reduced due to high ambient temperatures.
FOUR RED FLASHES: Four flashes, a pause and
then again four flashes and a pause - Battery
Fault: Charge time exceeded. This indicates a
problem with the battery pack voltage not reaching
the required nominal level within the maximum
time allowed.
SIX RED FLASHES: Six flashes, a pause and
then again six flashes and a pause - Charger
Fault: An internal fault has been detected. If this
fault is displayed again after unplugging the
charger’s DC power cord and plugging it back in,
the charger must be taken to a qualified service
center.
Status
