Hello fellow carters,
I need some help troubleshooting some issues I had with my golf cart while out for a ride yesterday. Perfectly Working Golf Cart Stopped Running and Runs Slow Now. After looking at it closer today I think I may have a few things going on, some minor while most are major as my cart is not running right now. Let me give you the basics of my cart followed by an outline of issues/symptoms.
2005 EZGO 36v electric
Freedom chip
Non-lifted
New Trojan batteries
Issues/Symptoms
How issue started:
1. Driving on pavement to level dirt field
2. Cart stopped completely with no pulling or jerking
3. Will not move forward or backward
4. Got back on pavement and cart would run but very slowly
5. Smoke coming from left rear wheel with heavy burning smell when driving home
6. Hard to press brake pedal
Jacked rear end up to inspect:
1. Removed wheel and brake drum
a. Drum very difficult to remove
2. Brake cable at axel end doesn’t look the same as the right rear wheel
a. The sheathing looks to be pulled from the coupler that mounts to the back of the drum back plate and is bunched up at the coupler– not smooth like other side.
3. Can move axel by hand easily forwards and backwards
a. Other wheel spins in opposite direction
b. No clicking, popping, grinding noises heard – no noise at all
4. When pressing gas the wheels will spin for 5 to 10 seconds and then come to a stop while the pedal is still pressed.
a. Again, no noises hear except for the spinning of the wheel/axel
b. After it stops and I let off the pedal and press again it moves half a rotation and then stops and the next time it will not spin again.
c. After sitting for 5 minutes or so it will do this all over again
5. Brake pedal is easy to press but equalizer linkage is pulled towards the left rear wheel, both with brake pressed and released.
I feel like I have a couple issues going on here.
1. I will probably need to replace the shoes and drum on the left rear but will take off right rear to compare the shoes and drum for any differences.
2. I will replace the left brake cable as I don’t like the look of it.
3. Bad bearing on left axel?
4. Bad axel?
5. Or could this be motor/controller issue given the description on item 4 a, b, c?
All comments and suggestions would be greatly appreciated in troubleshooting this. BTW, I have the Technician’s Repair and Service Manual and some decent mechanical skills although carts are new hobby.
Thanks,
Jason
Freedom chip
Non-lifted
Issues/Symptoms
How issue started:
4. Bad axel?
Thanks,
Jason
