This was in one of the Military Vehicle Club newsletters I just got....
Here is an interesting article submitted for our members consideration, 'Penetrating Oils'.
Recently “Machinist Workshop Magazine” did a test on penetrating oils. Using nuts and bolts that they ‘scientifically rusted’ to a uniform degree by soaking in salt water, they then tested the break-out torque required to loosen the nuts.
They treated the nuts with a variety of penetrants and measured the torque required to loosen them.
This is what they came up with:
Nothing: 516 lbs
WD-40: 238 lbs;
PB Blaster: 214 lbs;
Liquid Wrench: 127 lbs,
Kano Kroil: 106 lbs
(ATF)/Acetone mix (50/50): 50 lbs.
This last “shop brew” of 50% automatic transmission fluid and 50% acetone appears to beat
out the commercially prepared products costing far more.
Another common ‘shop made” rust buster is Glycol based brake fluid mixed with a bit of Acetone.
I have used this myself and it really works great. *Just be careful as brake fluid will remove paint!
Nothing: 516 lbs
WD-40: 238 lbs;
Kano Kroil: 106 lbs
