Patriot By Classi Carts
Mdgarzone
Has anyone heard of this Patriot by Classi Carts golf cart, if so where do I find parts for it?
Zman
It is a Chinese made cart and it is a clone of a Fairplay cart , which is a clone of a EZGO cart. Any questions?
Zman
Does it have a lever for forward or reverse? if so it is a series wound motor, but i think it is more modern and has a sepex wound motor meaning it has a electric switch for F&R. Does it have a amd motor?
Mdgarzone
It also has a rocker switch on the dashboard
Zman
Motor looks to be in bad shape, why is controller unplugged ? If both are bad i recommend not spending the money to fix. That particular motor and rear axle had many problems with snapping the axles, replacing the motor is impossible, no one in the US makes that flat mounting plate style motor so you would have to find someone to rebuild it. Replacement axles are no longer available.
Motor can be rebuilt by Luna industries in Tucson AZ.
Controller can also be rebuilt
Just fyi
