Old cart Newbee!
tugbuggy
The wife who is definitely the smarter of the two of us said to drive the thing in a ditch. I don't have the heart, this cart has given great service hauling helicopters and airplanes around the flight line for many years. I replaced it with a new old cart and brought the tugbuggy home. So far it's only cost me $650.00 rounded down from $700.00. It's a 75 EZGO with a lift kit, left leaning list and best I can tell a Gator rear end or shocks' or both. New batts, wires, and it warps out about 1 mph up a hill if I push with my good leg. I suppose this is more complicated than I assumed. Any advice on where to go from here (no comments about ditches please).
Welcome to the forum...
Are you sure all 6 batteries are wired correctly? Take a look at the resistor coils for broken coils or bad connections.
As a guess I would check out the brushes in the motor. After 36 years as a tow tractor they may be getting on the short side and should cost a lot less than the set of batteries. :)
tugbuggy
Working through a problem with one new battery only showing 6.0 volts. Charging it by itself tonight. The wires were reversed during the first charge (my bad). I will look at the brushes on the motor and report back.
I see it happen a lot. You should be fine after getting the battery charged and wired correctly. :thumbsup: Let us know how it works out.
tugbuggy
Thanks for the help Gale and Hotrod. Brushes dont appear to have a wear indicator visible so they are either toast or very short brushes. The motor looks good inside but really nasty. I don't want to mess with pulling the motor so I think I will get the old electro bath in a can and call it good. All the non battery wires are #4 and look ok as well. I think clean all the contacts and posts and save the money for an overhaul on the totally wore slap out steering unit. Still can't get the one battery to take a charge over 6.2 volts, it goes back tomorrow. No broken coils. The locking portion of the hill brake does'nt stay latched. I am going to try swapping the rear spring/shocks ( John Deere ) to see if it helps level the cart out. The mudder tires are in great shape and loud at higher speeds but the left front rubs during right turns no rubs turning left
Good news is,,, The cart was much stronger today after the second and third cycle on the batteries I had a hoot scootin around on flat ground and yes Gale I did fly...right down the hills. I feel like the uphill speed tripled at least so I am making progress. So at this point I will keep improving on the power issues, I need brushes and a service book or something so I know what I am looking at. Can I overhaul the steering unit or should I send it somewhere. Thanks again for your advise
Remember new batteries will not give max power until after 20+ recharge cycles. If you reversed charged the one battery I would give it several more cycles to equalize again. You got the electrons confused and they do not know where they are coming or going. :rotflmao:
tugbuggy
New brushes really made no difference in the power. Does anyone have an opinion on the most economical upgrades I could do to get a cart that will pull weight and hills better I'm not concerned with speed so much. Again it's a 75 ezgo 36v.
tugbuggy
Thanks again! I can't get my head around the fact this cart was towing or pushing 5000+lbs with little effort but the slightest incline slows the thing to a crawl. It has pep in forward and reverse on level ground. I will get with Lightning Designs.
tugbuggy
I have about three good charge cycles on the new set of batteries. Yesterday I moved 5 ton of crush and run and about a hundred bags of mulch. I guess I loaded 200 or so, per run. Each trip was up and down a very steep hill with a sharp turn in the middle. For being an old girl I was quite impressed with the tugbuggy. Last week I replaced the front wheel bearings but the oversize tires are still rubbing on the steering arms? I am sure the front end is worn out but what bearing would be causing this. Tie-rod bearings all seem to be okay.
What size tires are they? If they're wider than stock and you don't have offset wheels or wheel spacers that could be why they're rubbing.
tugbuggy
Thanks Gale my cart climbs like a billy goat. I was so proud gettin the ole ladies attention and tryin not to fall off climing the hill in my back yard. Hot rod, I did not know about spacers, got some today (1"ers), OMG no more rub. Thanks guys I am fixed and workin. My back and ankles (army wounds) will always hate you (just fooling). I took the hill brake apart worked it with a dremel and it still seems weak. Pads are okay but something is hanging up in the cables. Now that I got some work out of her I don't mind tinkering. You guys are great!
