bobsusancart
Replacing brake shoes 84 cc found oil or grease in brake on driver side. After cleaning found cir-clip and spring that I guess holds the axle seal and bearing in place. If I remove the clip can I remove the axle and replace the seal? Is it difficult to re-assemble? Also probably need to add oil or grease, haven't seen a place to do that yet but I haven't crawled under the cart.
