oil light
jmelvin70
Anyone know why the oil light keeps coming on and off . When i put the pedal to the floor it will come on then when I let off the gas pedal it goes back off. Its got new oil and oil filter. Any suggestions on what the problem could be? Thanks
shadowman
any type of lift to cart? what wt. oil?..................................
Bigone65
I have the same issue just changed oil and put in Royal Purple 15w40 synthetic oil figured it was a good oil and a little heavier weight for hot weather. I hope its not the oil at 16 dollars a litre.
dirtysouth
The oil sending unit is in the front of the engine, as long as the oil is full you should be fine.
