Noise
Kbrown60
The font end of my club car makes a noise, a creaking noise when I turn or go over curb. Any suggestions. Not sure if shocks or how to lubricate.
JRay
Spring bushings most likely. Spray some wd40 on them or install new bushings. Bushings are only a few dollars.
shadowman
you have grease fittings on the tie rod ends so while your at it with the wd-40 greaes all the fittings also...............................
dirtysouth
Check/tighten the bolts that hold the leaf spring mount to the frame. The steel on aluminum tends to creak/squeek.
