I have an 04 precedent that gets used pretty often. When I pushed the pedal I can hear a click but the engine doesn't start. I pushed the pedal a few more times and the engine started up and ran though I ended up not driving anywhere. The next day there was a puddle of gas under the cart. My first thought is battery so I will check it. After reading the posts about starter/generator and voltage regulator problems I assume I need to check the battery first and rule that out then the voltage reg and then the starter gen if the first 2 don't fix it. Any suggestions??
Andy
Andy
