No Spark After Changing Starter Generator on a 2017 EZGO ST-400
Clubman
A man contacted me said he has to keep charging his battery on a 2017 EZGO ST-400 so he decided to replace the starter/generator. Since he has done that now the cart won’t run. I told him how to check to see if he has spark coming out of the plug wire and he said no spark ,before he changed the starter/ generator he had spark. Could he have done something when changing the starter/ generator to cause the no spark problem?
EzgoTech
It is possible the rotation is incorrect causing it to not spark. Also seen the pulsar wires not making a good connection causing that issue.
