I have a 1990 ez go marathon...Want to lift it 5 inchs...All I could find is a 4 inch block lift....I want to know how much mods. will have to be done for a lift kit for a 94/2000 kit...Found a good deal on a combo package....
An axle lift is the way I wanted to go. But may just go with blocks...Will get the bolt pattern and material and get some welded...Then I can spend more on tires and rims...lol
and now for the front we used the 95 and up front beam and relocated the shock mounts, use 95 newer front springs and cut and widened the tie rod sleeves using DOM tubing.. the beam and tie rod sleeves need painted or powder coated
if this doenst make sense then wait till pics are posted
front and rear lift new spindles and hubs front leaf springs shocks tie rods $275.00 plus shipping
