I have a 1988 club car, gas powered cart used very little. Has not been ran in about 7 years. I drained all the old gas out and put in fresh. Changed both fuel filters and spark plug. The cart ran right out of the barn without doing any of these things but then started giving me problems about 30 minutes later at the camp ground. Took off carb and cleaned it since then and put it back on which the cart ran fine for about 50 feet then will not run. Turns over good just no gas on the spark plug. Getting fuel surges out of the gas line when I disconnected it from the fuel tank and also from near the carburator. I also have fuel coming out of the bowl when I loosen the nut on the bottom so I know that I have fuel getting into the carb. When I go to blow air through the carb with my mouth over the fuel inlet I cannot blow through it. I am just about to give up on this and take it to a mechanic but hoped that someone could help me on this forum first. It may be something simple that I am overlooking. Carb has been taken off and cleaned twice now so really think that it may be an adjustment problem or something. No visible holes in any of the lines but can take those off and check alot better if anyone thinks that is the problem. Thank you for your time.
