Newbie with G1A
Nugget Bill
I just bought my first cart and I think it is a G1 from what I read it has the buckets seats? I assume it is a 4 stroke but there is a oil tank behind the fuel tank is this actually a 2 stroke? Gas was bad when I brought it home cleaned tank and changed the plug,I can get it to run with the choke but keeps stalling could this be the fuel pump? Is there any place to get a service manual without spending a small fortune? Thanks in advance
Welcome to the forum.
If it's a G1 it's a 2 stroke. I'd start with taking the carb apart and give it a good cleaning and blow it out with a compressor. Make sure the lines from the oil tank are connected. If not you'll need to mix the oil/gas.
Nugget Bill
Thanks oil line is connected and it does run some what. I will tier into the carbm how do you know if the oiler is working?
Nugget Bill
I finally got time to taking the carb off and cleaning, the motor seems to run fine and has some speed to the cart. Should I assume the oiler is working on the unit?
