hey guys. I am new to the forum and to the whole golf cart scene in general. I have a 93 ezgo electric I believe its a textron but not 100%.I got in after it sat for years. The original problem was it had a axle bearing that went out and the axle walked out of the diff..So after fixing this problem I had a different motor from a newer model that I replaced the original with because all the terminals snapped off while replacing the bearing behind the motor.Any way on my first test run while it was running great and it just died all of a sudden. Now all I get is a click from the solenoid. I have reference voltage of 38v. I have the same to the controller and all positions of the motor. I figured I have no ground to the motor because if i jump b- to the m- terminal of the controller the cart does want to move.What should be my next step in figuring this out? I checked the micro switch for continuity and checked ok. the throttle box says pb-15 and the controller is a curtis.
