Newbe needs help
Monte Cristo
I have a 2003 refurbished EZ-Go electric cart and the brake lights are sticking. If I unplug the wire to the little apparatus hooked onto the brake, they go out. I tried spraying silicone on the plastic apparatus, but that did not help. Do I need to replace the apparatus and if so what is it called so I can order it.
Thank You for your help.
The Texan
If it's the stock EZGO setup the switch is a micro switch, E-Z-GO part number is 10606-G8. You can test the micro switch with a ohm meter.
