New Yamaha G16E Controller
Gooney43
Put new controller on my Yamaha G16E and now when I press pedal it goes but when I press all the way down it stops. Any thoughts?
Gooney43
Thanks! It’s a Curtis 1205M 500 amp. I put a bigger motor in and it went faster but had no power going up hills so I read if I put a higher amp controller in it might help. could it need a heavy duty solenoid maybe?
Does the throttle respond like it should until you get to full throttle? It sounds like the throttle input is set wrong on the controller. @Diode may be able to help you out when he sees your question.
That would be my guess also sounds like it slows down the more throttle you give it I think the Curtis 1205M controller is programmable but you’re gonna need the special software or handheld programmer.
Did you specify throttle when you bought it
Gooney43
It works good until I push the pedal a little more than half way then it stops. I do remember reading about programming it but when I bought it it said it would work for my cart.
Gooney43
No I didn’t specify throttle. I just got it on Amazon because it said it would work on my model. Im not much of a mechanic. I think I bit off more than I can chew trying to make it go faster😜
Gooney43
Thanks for the help! I think I’ll return the controller after looking into programmer for it $$$$$. Way over my head!!
I’m not a Yamaha person so do they have ITS throttles If so there are two different ones one is 0 to 2 V and one is 0 to 3 or something like that and don’t expect to go faster with a bigger controller I can get you an alltrax controller which has free programming software and comes pre-programmed
And I’m guessing you have a series cart
Gooney43
The motor is an Advanced Motor AU2500 36V 4HP. I don’t know what throttle it has. I believe it is a series cart. My concern isn’t the speed. The reason I put the bigger motor in was because it couldn’t make it up hills with two people in it when golfing and being clueless about this stuff I thought just putting a bigger motor would help. Now after doing a little research I realize other stuff has to be updated also. Any help would be much appreciated because like I said I’m pretty clueless about this stuff.
I think we should start with batteries put a meter on the batteries and go up that hill let’s see what it drops to
