New hd F&R switch
driver9iron
Replaced F&R switch with new hd F&R switch. seemed very hard to switch back and forth by hand when I took it out of the box. installed switch and as expected handle by leg almost won't move it without extreme pressure. Would it be a no no to loosen middle nut on back side of switch to get it to switch easier? 1995 Electric EZ go
As long as it has a lock nut like it should you can back it off a little to make it shift easier. Don't loosen it to much though.
dirtysouth
If you loosen it to far you'll defeat the purpose of having the hd switch.
BCGC
check the linkage bar. make sur it not hitting anything be careful not to loosen the nut to much if you running high volts you'll burn it up. use a electrical greese.
driver9iron
switch rod is not binding against anything but it does not look the rod I see on different parts sites. This one has a swivel on each end instead of solid ends I see on the parts sites. Is the swivel end rod the original and they have just changed the design or could this be something someone just riged up to work?
