Ron's EZgo has a 30hp Vtwin and a long travel A arm front end and it will wheelie like crazy. But rides so soft and smooth. Mine was like I had a solid connection with the tires. Haha
If this motor has a rev limiter, then what's the reason for the govener ?
I like the feel of a lawn tractor or go cart throttle, this cart has a odd spongy throttle.
I don't need more speed or risk tossing a rod, just a more direct connection to the carb would be nice.
Yeah I like it having the limiter, but still don't see the point of a govener unless it keeps it from revving to high, but that's the limiter's job right ?
The reason for both is you don't want to be hitting the rev limiter all the time. Even with the governor adjusted at it's stock setting in certain conditions like going downhill at full throttle it's possible for rev limiter to kick in. The best bet is to set the governor until the engine is just hitting the rev limiter at wide open throttle on level ground than back off on the adjustment a little. After that if the rev limiter ever kicks in just let off the throttle a little.
Yeah I know this motor especially doesn't like higher RPMs like some others, even the ol B&S 5hp can go a bit higher than this one.
I just can't stand how it slows me down, let off the throttle and back on and it gets back up to speed again.
But that's just me.
Got a Kawasaki 2004 ZX-10 muffler im about to adapt on.. should actually be quieter than the one that's on it, it being a Kawasaki KF-82 engine (341cc) I thought a Kawie pipe would be appropriate..
What do you guys think of the Kawasaki FJ400 OHV motor ?
I like my ol flathead 341cc but in the long run parts are hard to get, if the motor is in great shape is it very durable ?
The Kawasaki FJ400 is a good engine. The problem you'll have is the older Club Car golf cart engines rotate in the opposite direction so the cart would run forward in reverse and reverse in forward.
