Ballscratcher
My question arises from a different model cart but may be helpful to all. On a new factory OEM carburetor I bought there was no visible hi speed adjustments There was a brass screw where one should be . I took it out and there was a adjusting screw under it. So, because I wanted to know I loosened it. It broke loose with a little click so I put it back the way it was figuring it was tight for a reason . OK guys, was I right to tighten it back or not? My golf cart has good fire new fuel and filter but doesn't fire and doesn't seem to be getting any fuel unless I squirt some gas in the plug hole then it does fire.
Thank. Again
Thank. Again
