Need DCS Electronic Speed Controller...what vendor
JK-IZ
Like the title says, which vendor should i use. I need to get me a speed controller for an EZGO part number 73144G06.
Thanks,
Iz
dougmcp
The controller is the weak link in a DCS cart. If you are running oversized tires on a lift, stock controllers are not a good idea.
Any of the sponsors should be able to help you out, just click on them and call if you don't see the info.
JK-IZ
I am not running anything aftermarket...its all stock. Is there an aftermarket controller that you guys recomend?
dougmcp
IMO, the stock controller is fine for an all stock cart, the only time you may need an upgrade is if you mod the cart with larger tires, rear seat etc.
Make sure your batteries always have a good charge.
just throwin' this out there :shutup: if the stock controllers are known to have issues would it not be better to spend the money on a unit with a better track record. a few hundred dollars more now would assure a trouble free future and if one decided to add seats etc down the road the upgrade would be in place :twocents:
