Need 6" HD Lift Kit for 2012 Club Car Precedent
Okay. So I finished the lift this morning without using the cup washers or flat washers. Are you saying I have to this all apart again? That may explain how bad the instructions were. What else may have been missing from these instructions? Where can I get the correct instructions? I've included a picture below of the box to see if I have the correct kit. I also have a picture of the instructions I received and my brake issue.
. They are not on the website.
Also I have uneven non-working brakes now. When I push the pedal down it doesn't really apply break pressure until it gets to the parking brake and screeches to a halt. Both cables where too tight to fit in the bracket so they are not in there.
Thanks
After looking a little more at the brakes... I'm wondering If I can fix it by pulling some slack toward the rear after the spring click on the passenger side. You can see in the picture how loose the passenger side is and how tight the drivers side is. Then maybe I can play with the adjustment bolt by the pedal. Unless something is going on with the brakes themselves.
Shootrig
I have a six inch All Sports Lift, I removed the hanger clips from my brake cables and it works just fine. On mine, had I left the hangers in place, it would have put a constant pressure on the cables and therefore kept the brakes engaged.
Are the hanger clips you are referring to the ones that are attached to the leaf spring bolt? I left the cable running through those clips but removed the cable from the bracket on the axle.
:cheers:
dirtysouth
:cheers:
Yup. If you're not happy I will gladly pick it up and refund your $. My cell is 850 637 4464 for tech. The safety washers aren't a necessity. The washers on the u bolts are kinda a given. I realize our instructions suck. Mad jakes doesn't have a HD lift. They're all knock offs of mine. Maybe I'll return the favor and copy their instructions. If you'd like to return the lift contact the shop 866 291 5244. You won't find a better quality lift kit in the world. Fact...
Steve
dirtysouth
Still dialing front end in as of about 8:00 this evening. Might need a new steering ball joint, oe part. Haven't heard back but said I'd send new one if necessary. Hopefully he's got it dialed in and done, :hattip:
